SD Card slot - Creating/Developing the driver/kext
For anyone brave enough to attempt a Dell Mini 9 OS X installation
Postby UnaClocker on Sat Oct 18, 2008 4:06 pm
I figure we can use this thread to brainstorm a way to get the SD Card slot to start working in OS X.
The slot is a JMicron device. The good news is that it DOES work in Linux. Linux drivers have been ported to OS X in the past, such as the Tulip driver, which supports some network cards (I think I have an old Linksys that uses the Tulip driver in OS X on my main machine). So the first step might be getting the source for the driver extracted from Linux. Then we're going to need a serious guru to figure out how to compile it for OS X. :)
I wonder.. If the Linux driver has already been ported to BSD? Or if there's already a BSD equivalent? That would make it much more close to plug and play.
Dell Mini 9 with a RunCore 64gb SSD running OS X Leopard 10.5.6
User avatar
UnaClocker
Mini OS X Specialist
Re: SD Card slot - Brainstorming a solution
Postby loonix on Sat Oct 18, 2008 6:28 pm
Are you sure about the chip set? When researching JMicron I am only finding serial products their chipsets run http://www.jmicron.com/Product_list.htm
My Dell mini is not due till 11/13/08 :evil:
In the meantime can someone who has ubuntu running on it post a
Code: Select all
dmesg
and
Code: Select all
lsmod
please?
Thanks
AR aka. loonix
AR aka. loonix
Dell 9 mini - OSX (Type 11 method) 10.5.6
User avatar
loonix
Novice Member
Postby UnaClocker on Sat Oct 18, 2008 6:50 pm
User avatar
UnaClocker
Postby loonix on Sat Oct 18, 2008 7:51 pm
Cool
My bad ;-)
looks like the acer aspire one has the same card reader and the guys running osx on it have similar issues
http://www.aspireoneuser.com/forum/viewtopic.php?f=14&t=5117
let's keep searching
AR aka. loonix
AR aka. loonix
User avatar
loonix
Novice Member
Postby mrwolff on Sat Oct 18, 2008 9:38 pm
I have Ubuntu's live CD. Will that work to pull up those terminal entries for you? Or does it need to be installed? I'm guessing it would depend on if it worked in Ubuntu to begin with. lol
Everything that is down can go up, but only some of what is up can go down.
|Type11 EFI 10.5.5, 2gb, Touch screen in progress|
mrwolff
Mini Member
Postby Type11 on Sat Oct 18, 2008 11:18 pm
Live 8.10 cd does not have a driver for it. Actually I am not sure I have seen it work in my 8.10 install but to tell the trith not sure I have really tried it. Perhaps it is only on the dell ubuntu image? Either way it is not on the live cd.
Type11
Amateur Member
Postby AlexanderJohn on Mon Oct 20, 2008 3:10 am
I'll be installing 8.10 onto an external hdd via usb tonight God willing ( he may not be as I've managed to screw up 4 downloads so far. 52% this time! ) I'm going to try and tackle the sd problem.. I'm thinking that maybe I should've waited 6 months before I bought mine... then everything would work! hehe I'm a glutton for punishment though... gg
AlexanderJohn
Mini Member
Postby WolfKeeper on Mon Oct 20, 2008 3:48 am
Type11 wrote:Live 8.10 cd does not have a driver for it. Actually I am not sure I have seen it work in my 8.10 install but to tell the trith not sure I have really tried it. Perhaps it is only on the dell ubuntu image? Either way it is not on the live cd.
I just loaded my 8.10 live "CD" (it's been installed to a USB drive key) and it does recognize the card reader, as it instantly mounted a Canon 2GB card that I had inserted.
User avatar
WolfKeeper
Amateur Member
Postby robios on Mon Oct 20, 2008 4:09 am
Googling around some forums and found some interesting threads... It may not help, but I just leave them here for brainstroming...
http://ubuntuforums.org/showthread.php?t=894071
-> Looks like a Ricoh driver can be used???
http://www.linuxquestions.org/questions ... tu-536646/
http://hackint0sh.org/forum/showthread.php?p=357009
http://forum.insanelymac.com/index.php? ... 036&st=480
robios
Mini-Mini Member
Postby Type11 on Mon Oct 20, 2008 2:15 pm
Humm interesting I did not see my card when on the live cd. it was a 16 GB card. I hope this does not mean the slot does not support SDHC, but that would be dumb to not support that these days. Maybe I had formatted it strange. Anyway I will try it again and see if I can figure out the module loaded for it.
Type11
Amateur Member
Next
Return to Mac OS X
Who is online
Users browsing this forum: DanielN, Google Adsense [Bot], sugus and 3 guests
